Maxtor Upgrade Problem with Amstrad Sky +
Discussion in 'Sky Digital TV Forum' started by ched, Dec 21, 2004.
  1. ched
    ched
    Nov 11, 2004
    846
    43
    Sunny Blackpool
    +110
    I have upgraded my Amstrad Sky+ box about 3 days ago and all went well. I used a Maxtor 6Y160P0 160Gb hard drive. It all seemed to work fine. Today I started to get a green screen with a couple of white vertical bars that moved from side to side. Then the box went into standby. I have tried powering down and restarting but it wont come out of standby. I have put the original hard drive in and the SKY+ works fine. I havent access to a desktop computer for a couple of weeks so I cant check if its a hard drive failure or something else.
    Does anyone have any ideas on a fix as I would like the extra hrs or recording time over Christmas??????????
    If its just a simple low level format I could probably borrow a desktop computer for a few hrs.
    Please, can anyone provide any clues to the problem??? :lease: :lease:
  2. philipb
    philipb
    Mar 6, 2002
    2,034
    63
    Swindon
    +149
    If the original drive works fine, then it must be the new drive.
    Either faulty, or, have you set the jumper to CSEL?
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Sounds like a faulty drive to me.
