maxtor hard disc upgrade
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Vorta, Dec 6, 2004.
  1. Vorta
    Vorta
    hello folks, just a couple of questions, if i opt for a maxtor drive to upgrade my v2 sky+ box do i really need to connect it to a pc and run the tools to make it quiet and not write verify or will it be ok to fit as is?
    any advice would be most welcomed,
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    No, you don't. I fitted a Maxtor 200GB drive to my Pace V2 Sky+ box without running the utilities, and it is as quiet as the drive that came out. Just make sure you turn Instant Rewind OFF before you start, and run Housekeeping (Services 4,0,1, Select) when you've fitted the new drive. After you've verified that the box is working, you can turn Instant Rewind back on if you wish.
  3. Vorta
    Vorta
    many thanks Nick UK
