maxtor 200gig
Discussion in 'Satellite TV, Sky TV & FreeSat' started by tcgills, Jun 3, 2005.
  1. tcgills
    tcgills
    Dec 26, 2002
    92
    it just doesnt like it in my pace v2 put maxtor 40 gig back in works fine tested 200 gig on computer works fine put it in sky box wont work any ideas ?
    7200 ide udma133 8mb cache 6b200p0
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Are you aware of the "secret menu" ?
    Press Services, 4, 0, 1, select
    Then choose "housekeeping".
    This prepares a new drive for use with Sky+
  3. Member 55145
    Member 55145
    Jan 18, 2005
    12,079
    +3,480
    it better bloody work, cause im planning on getting sky + and i have the exact same drive
  4. tomsky
    tomsky
    Dec 19, 2004
    238
    manchester
    +7
    :D you need to choose full system reset, which is what i did as housekeeping did not work for me.A full reset prepares the drive,housekeeping does not and make sure the jumper on the hdd is set to cable select (cs) :smashin:
  5. tcgills
    tcgills
    Dec 26, 2002
    92
    went into 01 select hidden selection and the only one listed is reset selected this it then goes into housekeeping so basically it is one and the same tryed reformatting the new hard drive aswell but still the sky box just wont work with this disk drive strange when other people have used it no probelm
