Maxium subwoofer power limit?
Discussion in 'Subwoofers' started by Saya2001, Aug 26, 2004.
  1. Saya2001
    Saya2001
    Jul 20, 2004
    90
    Hi there
    I have a Denon 2805 amp. Whats the maximum power sub woofer limit for it?
    COnsidering i want an active sub. Also is ther more than one way to connect it to my HT?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,906
    The power of the active sub is more a factor of it's design than loudness as generally the smaller the enclosure, the more power needed.
    The original REL Q Bass was plenty loud enough with it's 40 watts
    Most subs can be connected at high level via the speaker connectors on the amp as well as via the LFE phono lead
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    I reckon you'll need a 5000 Watt subwoofer especially as you think the MJ Ref 1 isn't good enough. Oh and how's the REL Q150 coming along, £500 well spent eh?
