Maximum Scart Length
Discussion in 'Satellite TV, Sky TV & FreeSat' started by nits2004, Mar 22, 2005.
  1. nits2004
    nits2004
    Prob a rubbish question but i am not very technical. I Got a plasma screen which i want to wall mount. There are 2 Scart connections on it. I already have sky digital, but now the scart from Sky box to TV is too short. What us the maximum length scart cable to use. would 5m be bad quality? i have heard that Gold plated oxygen free cables are fine. Can anyone advise me please. The cable is going to go up into the ceiling and back down behind wall so 5m is prob only size i can get.
  2. ChrisThwaites
    ChrisThwaites
    10m scarts are avaliable - i use twin screened oxygen free ones (gold flashed) - Never had a problem with them, the cheaper ones i got a bit of interferance with mains (only thing i could put it down to). But these ones were fine.
  3. nits2004
    nits2004
    thanks chris. i was just worried that the longer the cable, the worse the reception you got. thanks for your help
  4. ChrisThwaites
    ChrisThwaites
    If you want one i can supply?
  5. Astaroth
    Astaroth
    Jun 22, 2004
    2,243
    48
    London
    +95
    The longer the cable the greater the chance of signal degridation and the greater the chance of picking up interferance from other sources.
    Buying a higher quality cable will reduce the problems and trying to make sure you arent passing near mains ring etc will help.
