Maximum Scart Length
Discussion in 'Cables & Switches' started by Confused_Roy, Feb 24, 2005.
  1. Confused_Roy
    Confused_Roy
    Hi folks well i have a wee querry i have plasma on 1 wall and av equipment other end off room was jus goin to run scart leads between the two but its about 15 metres worth off cable, questions
    1:) Will i loose signal
    2:)Any suggestions?
    I posted same thing a few days ago but couldnt get any help
    Thankls in advance
    Roy
  2. Confused_Roy
    Confused_Roy
    Can anyone help
  3. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    24,635
    2
    In a secret location with Jennifer Lawrence
    +12,093
    15 mtrs! thats a bloody long room.
    I don't think it's ideal but give it a go and see. Haven't used a scart cable that length, but have tried VGA cables that long and I have had no problem.
    Get a dirt cheap cable and if it works at all to a decent degree, then you could go for a more expensive one.
  4. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    I have a 5m custom IXOS lead, I think it too long, personally SCART should be limited to 3m, or my choice 0m :) 15m well I hope you are an optimist, you will get something down the lead but I wouldn't like to comment on quality ;)
  5. jsap
    jsap
    Jan 17, 2005
    95
    Glasgow
    AFAIK you can get powered boosters from places like keene, or you can get a different type of adaptor which will send the signal down CAT-5 cable and convert to scart at the other end.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    I have used 20m scart cables a couple of times!!!! needs a bloody strong signal and good cable but can be done! If you can try and get length down top 10-12m
