Maximum Ram Limit On Laptops?
Discussion in 'Computer Components' started by dean randle, Oct 9, 2005.
  1. dean randle
    dean randle
    Jan 9, 2003
    154
    UK (Bromley)
    +6
    I have a Panasonic Laptop which is a few years old now, and came with it's then maximum ram of 192 (iirc), but I was wondering if the limit is a true one, or whether you can go higher? What are the ramifications of going above the limit?
    Thanks,
    Dean.
  2. meansizzler
    meansizzler
    May 11, 2005
    7,588
    104
    London
    +266
    go to www.crucial.com , and type in your model there and they should tell you what's the max amount of ram you can put in there...
  3. dean randle
    dean randle
    Jan 9, 2003
    154
    UK (Bromley)
    +6
    Thanks, I couldn't find my pc on there, but I'm pretty sure it was at it's max. I was more curious as to why there is a max, and what are the implications of going over that?
