Maximum MDF size for screen?
Discussion in 'Projectors, Screens & Video Processors' started by jrwood, Sep 22, 2001.
  1. jrwood
    jrwood
    Hi,<br /> I was hoping to get some MDF (12mm thick) with the dimensions 88" (2235.2mm) by 54" (1371.6mm) from B&Q but the max size they do is 96" by 48" which can be cut down to 88" by 48". Anyone else managed to find a place which can do larger?.
    thanks!
