Maximum Mb for the DVD?
Discussion in 'Blu-ray & DVD Players & Recorders' started by tdale, Oct 3, 2004.
  1. tdale
    tdale
    Im aware that the max size is 4438Mb, is that the same if the DVD is written and finalised on a Recorder? I have an E85.
    I notice that with FR mode, the siz eappears to be more like 4100Mb, I assume this "buffer", is due to what is required if the max titles and chapters for the E85 is used? It would be ideal to use those megs, but i guess unles you recorded in say SP mdoe for a bit over 2 hours, for example, there isnt a way to fool FR mode to record more megs?
