maxell dvd-R pack of 50 from play.com
S
sne
play.com do 3 for price of 2 at 8.99
has anyone got a cheaper website please for these disks
they are superb
stephen
A
Analogue
Why are they "Superb"? How many have you recorded on? How many different DVD players have you tried to replay them on?What DVDR do you record them on??
I ask because I have found this brand to be about 50% only - I now stick to Verbatim
S
sne
ibuy lots as i record a lot of tv for my brother in australia
ive done about 150 discs over the years not one failure
i use a dvd ex85 and my brother has a sony
where do u buy yours from
stephen
Knyght_byte
so its 150 for £26, not 150 for £17 as your initial post would suggest
(just putting this to clarify for folks reading who may get confused like i sometimes do :D)
dicky
These Maxell are the absolute worst disks I have used in
my set-up - most probably a bad batch but I threw away
about 40 of them from a tub of 50.
Would not finalise on either of my PC rewriters (Pioneer
107 and 111) - did finalise in my Pioneer 5100 standalone
recorder though??
My Panasonic eh50 actually locked up and got the dreaded
self check - threw them after that - just my tuppence worth
but will never by Maxell again.
ROYOLD
The Panasonic DVD-R 1~16x using Taiyo Yuden TYG03 dye work fine in my old three year old machines and also the later models.
The offer at £19-56 for a spindle of 100 discs is still available at APRMEDIA and they are listed as being in stock. Unfortunately tho', unlike Play.com, the carriage isn't free.
http://www.aprmedia.co.uk/product.php?pid=3233
In the link it states that the top colour of these Panasonic discs is silver. That is incorrect. They are a matt orange and quite easy to write on. I use a BIC CD marker.
🎬 The Top 20 Most Anticipated Movies of 2024
Back
