Maxell dvd-r for panasonic e50 anygood?
Discussion in 'Blu-ray & DVD Players & Recorders' started by soup nazi, Jan 31, 2005.
  1. soup nazi
    soup nazi
    Are maxell dvd-r anygood with a pansonic e50?
    £14.99 in argos for 25,any cheaper online?
  2. adrianl
    adrianl
    Only has a pack of 5 Maxell but all worked fine on Panasonic E-85 if that's any help.
  3. captainpacific
    captainpacific
    Jan 9, 2005
    266
    Hampshire
    +51
    Unfortunately the Maxell brand name does not ensure good quality because they source their discs from several different manufacturers - some good, some bad. When buying discs it is far more helpful to ignore the brand and look at the manufacturer code. Take a look at http://www.digitalfaq.com/media/dvdmedia.htm and all will be clear.
    Generally, you will find much better deals on-line. Try SVP - a great supplier for price and service.
  4. Ian C.
    Ian C.
    Jul 8, 2004
    713
    28
    West Midlands
    +40
    Morrisons selling Memorex half price at
    moment £8.99 for 25 cant be bad :smashin:
  5. jpurkey
    jpurkey
    Yes it can. :) Nearly half the Memorex DVD-Rs I recorded on my Panasonic E75 had errors.
