Max Payne
Discussion in 'General Video Gaming Chat' started by Jasoon, Mar 16, 2002.
  1. Jasoon
    Jasoon
    Iv Just got my Xbox and I was trying the Tutorial on Max Payne and believe it or not I’m having a bit of bother with it.
    At one part you get the message from the phone and your told to jump over a wall I can see the wall at the end of the ally I can jump onto the boxes that are at the bottom of the wall but I cant get over the wall.
    I know it’s only the tutorial but its starting to annoy me that I can get over it.
    Can anyone tell me where I’m going wrong?
    Jason....
  2. Taz
    Taz
    I also had this problem!! When I tell you, you will kick yourself, just like I did! Basically, just jump on top of the air con unit on the wall, on the left of the pile of boxes, then that gets you high enough to hop over the wall !!
    :rolleyes:
    (it's a great game)
    micksowner :kisses:
  3. Jasoon
    Jasoon
    Thanks For the Help.
    Jason....
