Max length of HDMI cable from DV79?
Discussion in 'Blu-ray & DVD Players & Recorders' started by gregeas, Mar 27, 2006.
Tags:
  1. gregeas
    gregeas
    May 7, 2004
    175
    NYC USA
    +6
    I'm snaking cables this weekend to a projector I'm mounting on the ceiling of my theater room.
    I'm wondering how long the HDMI cable can be from the DV79. 25 feet should do it. Will I have any problems?
    I recall reading a post from an Arcam engineer that HDMI cables should not surpass X length from the DVD players. I don't want to install everything and then experience a problem... Thanks.
  2. ANDY_DUTTON
    ANDY_DUTTON
    Aug 27, 2002
    498
    28
    Cambridge
    +87
    From memory the specified limit for the HDMI interface is 7m approx 21 feet. However we have had 15m cables working in several systems. So long as you are using a good quality cable it should work OK. Try not to put tight bends or kinks in the cable as at HDMI signal speeds these can cause the signal to be partly reflected back to the source and this reduces the length they will work at.
    Regards,
    Andrew
  3. LFCRules
    LFCRules
    Sep 3, 2004
    2,682
    +188
    I've got a 10m Chord Company Silver Plus HDMI cable from my DV29 to my Screenplay 5700 projector, and it looks great to me. As Andy D says, keep the cable tidy, and you shouldn't have any problems :smashin:
    Andy
  4. gregeas
    gregeas
    May 7, 2004
    175
    NYC USA
    +6
    Thanks. I'm only 1m over the spec but hopefully will be okay.
  5. Dom996
    Dom996
    Jun 3, 2005
    1,061
    +29
    Also the power on the players output comes into this. The Arcams are very good at driving longer HDMI runs. The other thing to take into account is how long a run can one use for HD signals. A cable that will run 15m on DVD (576p) may not work in the future on 1080p.
