max dvi cable length
Discussion in 'Cables & Switches' started by rmask, May 26, 2005.
  1. rmask
    rmask
    Mar 25, 2005
    115
    +4
    pc > lcd tv
    would 9 meter dvi-dvi cable work?
    thanks
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,426
    The Borders
    +2,593
    rmask
    'Suck It and See' has to be the motto with DVI - there's no guarantee any DVI cable will work at that distance in all installations.
    We have BetterCables 9m DVI-D Display Magic cables on offer in the Cable PowerBuy section of the Forums.
    See http://www.avforums.com/forums/showthread.php?t=185961 - the cables are supplied on a Sale or Return basis.
    Best regards
    Joe
  3. rmask
    rmask
    Mar 25, 2005
    115
    +4
    thanks
    i'll probably try making one, using standard 1.8 meter as basis
  4. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    DIY and DVI don't mix. Bettervables DVI would be my first choice if you need 9m, with DIY you haven't a hope at that distance.
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,426
    The Borders
    +2,593
    Hello all
    Nic - there must be instructions somewhere on the web for splicing 10 x CAT5 cables to form a low cost DVI cable :devil:
    Speak soon.
    Joe
  6. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    tried it mate, it doesn't work :) You need that Gorilla bar....;)
  7. caleb
    caleb
    Sep 30, 2003
    368
    Cape Town (Ex Holmfirth Yorkshire)
    +3
    Without getting flamed - Monster cable do a 12 metre DVI cable but not sure of the quality over that length.
    From what I have heard on the various forums (or are the fora). over about 7 metres you tend to get signal drop out.
  8. Member 34135
    Member 34135
    Lindy SLD and Profigold cables work fine over these lengths, in fact the Lindy now goes to 25m albeit with limited resolution over 20m and we've never had any disappointment with them.
    Andy.
  9. rmask
    rmask
    Mar 25, 2005
    115
    +4
    Results of weekend tests:
    no more than 4.3 meters (used noname 1.8meter dvi>dvi cable as basis and noname cable to lengthen it)
    quality cable probably would add meter or two, but it still wont be enough :(
    video card: geforce 5900
    tested with philips 9976 tv and samsung 720T monitor
  10. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,426
    The Borders
    +2,593
    rmask
    I believe the cut and splice will snooker you - no matter what cable you use.
    You have three options:
    01. A decent quality 9m or longer copper cable; which works at the resolutions you require. We only install/supply cables that are tested at 1080P and above.
    02. A fibre optic DVI cable - we have used these at 20m and further where copper cables didn't work.
    03. A DVI extender - these are active signal boosters; they came in various specs to drive differing cable lengths; you can run DVI over a few KM if you want using one of these.
    Best regards
    Joe
  11. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    Just buy the better cables, I believe it will work for you in this situation. As you have found out all is not what it seems re DVI and a 'knowledge' is also needed to get past 5m. I have seen 15m work with one cable where 5m won't work with another, lots of factors involved here inc the chipset use, interference, the cable and the resolution it is used at (or more accurately the bandwidth also taking in freq).
  12. PJTX100
    PJTX100
    Dec 21, 2004
    8,132
    +563
    I'm using a 15m Lindy with no probs but don't doubt it may not be OK for all situations...PJ :)
  13. rmask
    rmask
    Mar 25, 2005
    115
    +4
    thanks everyone
    i'll probalby get some quality premade cable and do some testing
