Quantcast
maudio spdif switching problem?
vishnu
hi,
I have a DIO 2496.
Try to explain this best i can.
when i use winamp with asio output with the maudio control panel for spdif set for audio out this works fine.
If i then quit winamp and play a dvd the spdif control panel automatically changes to non audio and i get DD and DTS with no problems.
If i then quit out of that and run winamp again, the spdif control panel does not switch back to "audio" so i get no sound.
I either have to manually swicth it back, or if i make windows make a sound that will switch it back.
Is there any way of fixing this so i can just switch between the 2 progs without having to go into the maudio control panel?
Branxx
This is how is this meant to work. I noticed the same problem two years ago, repoted it to m-audio and was told it was an intended feature.
vishnu
Thanks for that.....
seems like an oversight to me though.
Did you find away round it at all?
CrispyXUK
I use Foobar2000 which is a much better player and you should get this problem
