MATTS from London with Tosh 100 - please read
Discussion in 'Blu-ray & DVD Players & Recorders' started by Justin, Jan 17, 2002.
  1. Justin
    Justin
    MATTS from London with Tosh 100. You said in a post last year that you had got your Tosh SD100e to read CDR's. Which make are those, and which CD burner / software did you use??
    Also - anyone know if the Tosh SD100e will read DVD-R, DVD+RW, DVD-RW ???
    J
  2. Justin
    Justin
    Anyone else know?
  3. HeadBanger
    HeadBanger
    Sep 22, 2000
    2,273
    116
    Ashingdon
    +511
    Justin,
    The CD was a maxell - i've got some at work here somewhere.
    I'll find one and post another reply giving the number.
    This is the only one I've found to work. The other guys that posted a thread were correct!
  4. HeadBanger
    HeadBanger
    Sep 22, 2000
    2,273
    116
    Ashingdon
    +511
    Justin,
    Right - the CDR that plays is a Maxell CD-R 74XL (650 MB) and the burner software used is Nero Burning ROM.
    Please buy one disc first and try it! Hope this helps.
  5. Justin
    Justin
    Matt,
    Multiregion Magic (www.multiregionmagic.co.uk) are also doing some CDRs at £8.99 (+£6 p&p!) that work on Tosh SD100.
    Justin.
    When I find someone who has a DVD recorder I'll try DVD-R / DVD+RW on it and see if they work aswell.
