Matsui Plasma at Dixons.
Discussion in 'Plasma TVs Forum' started by Steve_Whelan, May 12, 2005.
  1. Steve_Whelan
    Steve_Whelan
    Sep 22, 2004
    118
    +3
    Just saw an add for a new Matsui Plasma from Dixons from the Picture and spec list this looks very similar to the infamous Tiny. I think DSG could have a lot of problems on their hands.
  2. GAC
    GAC
    Feb 20, 2005
    32
    well its being brought in to replace the wonderfull techwood (yes im takking the miky) and its ment to be our entry level screen and as so will be hopless.
    to give you a rough idea about how good the techwoods are in one of our depots there are 400 screens sat there because there goosed, its hard to make a good coment as far as currys when it comes to plasma's as we seem to be determind to buy the cheapest pos we can.
  3. tetrarch
    tetrarch
    Jan 20, 2005
    60
    Sorry GAC but...
    Well, it's, wonderful, Techwood, I'm, Micky, it's, meant, such, hopeless, To, Techwoods, In they're, it's, comment, Currys, plasmas, determined, poss
    Regards
    Tet
  4. GAC
    GAC
    Feb 20, 2005
    32
    well i guess that shows me dosnt it !?
  5. theo cupier
    theo cupier
    Sep 18, 2004
    1,660
    63
    Amersham, Bucks
    +113
    you forgot 'taking'...
  6. simon33
    simon33
    You forgot 'taking'. :)
    Well, I, doesn't. ;)
  7. Drd
    Drd
    Jan 22, 2005
    1,904
    Approaching the doghouse at great speed
    +301
    If I was intelligent,worked for DSG (yes that's spelt oxymoron),and criticised them on this forum,then I too would suddenly be unable to spell! ;)
  8. GAC
    GAC
    Feb 20, 2005
    32
    hey i have a good idea il just shut up and let people buy them so we can have another tiny thread.
  9. Drd
    Drd
    Jan 22, 2005
    1,904
    +301
    Hey GAC, I'm on your side.Keep the inside information coming!!
  10. JeffLaws1
    JeffLaws1
    Well I thought the pos bit was a short for Pile Of S**t.
  11. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    we all make mishtakes shometimes.....I thought it was bad form to pull people up on spelling?
  12. Enquirer
    Enquirer
    I personally don't hold great expectations about the performance of the Matsui Plasma.
    BUT I would not form an opinion or advise someone to not buy or buy a product that I had not seen, used and tested.
    Its one thing to suggest caution and another to say don’t buy with little evidence.
    I have to say no one has actually said they have thoroughly tested one and the assumption that because it looks like another brand so it must be rubbish is not the most logical one.
    It may well turn out to be the same but I would always try to keep an open mind.
    Opinions on these forums about certain plasma sets are often not formed from first hand experience but just what they have read elsewhere or because of understandable personal bias because they own a different set.
    The best plasma IMHO is the one with the best picture quality to you and not a spec sheet.
    The vast investments from former budget brands is paying dividends just a few years ago the gulf between Japanese visual products and the rest was massive now it gets smaller and smaller every year.
    I feel too many people spending a grand for a set that will be in there living room for five years are too lazy and do not take the time to actually get off there sofa and go and look at all the options themselves .Forums are a good way to get background info and find suggestions for sets that you may not have heard of.
    After testing yourself you may well decide that certain recommendations are the right choice for you. You might feel spending a little more gets you a massive improvement. But unless you take the time and effort you will never really be certain that you did make the right choice.
    I would not also put down a make or model I had not seen or tested.
    Sorry for the rant.
  13. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    Yes, I am starting to notice a lot of this recently. Mistakes happen people :lesson:
  14. DannyG33
    DannyG33
    well my sister purchased one and it was delivered/installed yesterday,just spoken on the phone to her to see how it went,she says picture looks terrible and there installer/delivery man was there hours ,model is Matsui 42P600,comments are bad picture/pixel problem.shes running it with sky+,i also heard as well ages she said her areial was dead old,so maybes it,s not just the matsui plasma,s fault.
    dan
  15. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    You're being very generous, Danny. I don't think her aerial will affect the sky+ picture though. Sounds like GAC might be right on the money.
  16. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    call her back quick tell her to reject it (get it taken away) and to log on here and we will sonn have her up and runnning with a proper plasma!
  17. DannyG33
    DannyG33
    Maw
    very true,will have to ask her if her picture was spot-on with her other tv,
    H-Dragon
    she txt me before with the intention of sending it back lol..
    dan
    PS So will Sky Digital/Sky Digital + work with no house aerial at all then lads??
  18. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    no aerial is required for satellite service like sky just a dish......... no dish no picture at all.
  19. DannyG33
    DannyG33
    H-Dragon
    Think its deffo ruled out her aerial,its obviously the Mat Plasma at fault then..
    will have to find out when there coming for it,so she can get good advice on better quality plasma.
    Cheers Dan
  20. carjoem
    carjoem
    May 31, 2005
    17
    Could someone be kind enough to clarify what exactly the problem is with the Matsui Plasma - my pal had one installed at the weekend and as far as I ( and my pal ) are concerned the picture looks excellent. Similarly when browsing the shops the Techwood has had a picture as good as models with big brand names costing a lot more. I currently enjoy the Toshiba 33 inch CRT TV so I think I have a reasonable perspective. Just what is it that I cannot see, that might persuade me to spend £3 on a model that does not look as good picture wise ?
    Am I suffering " the kings new clothes syndrome " Could someone give me an intelligent answer please ?
  21. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Intelligent, no idea. The picture will depend on your perspective. If you are happy, go ahead. If all you have seen ate plasmas and TVs in stores like Dixons, you probably have little idea what constitutes a good picture. We are supposing that a 'good picture' is the nearest to real life/film that is possible. For that, you will need a top end screen, say a Panasonic PHD7, a scaler, and a highly skilled ISF calibration technician. I promise you will see the difference, even if it's only 2 out of these three! Or even 1 I should think. Really, you need a side by side to compare, but if you are happy with what you have, why worry?
  22. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    On what basis are you and your PAL basing this assesment of quality? The dodgy RF feed or £70 DVD and £70 scart lead combos that most karge store use to demonstrate thesebits of kit dont even offer 50% of the potential.............And i can assure you that DSG (dixons/currys etc) make far more more profit on there Onw brand kit than on branded kit with which it competes..........so it is in their interest to make the £1300 Matsui look better than a £2k anything else, it sells a lot of plasmas for them! If you (or your PAL) want to see a proper plasma i am sure we can point you in the direction of one!
  23. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Get the ball rolling now, once you have had a big scren going back to a normal telly makes a sure she is 100% happy before buying again even if it means waiting for 6 months for better screens to drop in price!
  24. qwerty786
    qwerty786
    Jun 21, 2008
    2
    Hi there can anyone help me please :lease:
    I brought a Matsui 42P600 Plasma when i brought it it was perfect. Then suddenly a Black line appeared down the middle of the screen it kept coming and going. But know the line aint going it just stuck there. But everything else is fine the sound, picture, Menu on the plasma ETC. can somebody PLEASE!! help me
    Thank You
  25. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    You'll probably need a technician to replace a board.
  26. qwerty786
    qwerty786
    Jun 21, 2008
    2
    Thankz 4 that mate. i really appreciate your help
