Matsui PL-607
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by dunnster, May 30, 2005.
  1. dunnster
    dunnster
    does anyone have a hack for a UK Matsui PL-607 portable DVD player?
    best wishes
  2. marcusattilius
    marcusattilius
    It's the same hack as for the Mustek PL-408T (there are several portable DVD players in this series which seem to come badged either Mustek or Matsui, but presumably apart from the badges are identical). You can find it at
    http://www.avforums.com/forums/showthread.php?t=214217
    and I've pasted it below as well. This worked for me first time and I have successfuly played Region 1 and Region 9 discs in it since.
    · Turn on your player.
    · Close DVD disk door without a disk inserted.
    · Press the following sequence of keys on your remote
    control.
    · Press "SET-UP".
    · Press “Next” (>>|) & then “Prev” (|<<).
    · Again press “Next” & then “Prev”.
    · Version 2 appears on top right hand corner of your TV
    screen (2 being your existing region code)
    · Change version (region) by pressing < button until 255
    appears (correct code for Multiregion).
    · Press "SET-UP" again & scroll down to exit.
    · Press " SET-UP " again.
    · Insert DVD disc and play.
  3. stsong
    stsong
    What about a Mustek PL-607, is Mustek the same as Matsui?
