Matsui DVDR 100 Manual
Discussion in 'Blu-ray & DVD Players & Recorders' started by soundstory, Mar 14, 2006.
  1. soundstory
    soundstory
    Feb 15, 2006
    4,414
    +229
    Hi Everybody
    I recently bought a Matsui DVDR 100 (god knows why I did!) but it came without a manual.
    & of course with all cheap things in life, it isn't simple to set-up!
    Anyone know where I can source the manual?
    Thanks in advance for your help!
  2. Bob Staines
    Bob Staines
    Dec 4, 2005
    125
    Hi there, I had a Matsui dvdr 100 but had to return it after a couple of months as it kept freezing up. As i remember the set up was quite easy just plug in and connect a scart and ariel and it automaticaly scanned for channels with on screen prompts. Then you press menu and select format disc and you are ready to record.
  3. 90210
    90210
    if you still need one let me know as i am sure this is the model i have. I dont think the manual will help you if you need a cofig set up though as i recll a seperate paper came about this and i dont have this hence why I can record video to dvd anymore as i have forgotten how to do it!
  4. beerhunter
    beerhunter
    Nov 9, 2005
    6,335
    Hampshire
    +740
    Have you tried DSG (FKA Dixons). Matsui is one of their brands.
