matsui 110 remote hack please
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by k thompson, Sep 13, 2001.
  1. k thompson
    k thompson
    has anyone got the hack for this old dvd .... so my poor old mate can play r1 discs <br />thanks guys
  2. poolking
    poolking
    Sep 2, 2001
    35
    With the remote control :
    Press Menu, 9, Open/Close, and 5<br />When the region page appears, press Mute.<br />When the region page appears again, press OK.<br />When the region page appears again, press Exit
    This is taken from the Handset Hack Archive at <a href="http://www.totaldvd.net/features/index.html" target="_blank">Total DVD</a>
  3. Grubert
    Grubert
    Jun 15, 2001
    601
    28
    +72
    According to <a href="http://www.dvd-reviewer.co.uk," target="_blank">www.dvd-reviewer.co.uk,</a> the newer batches of the Matsui 110 use a different hack. Here it goes:
    1. On your remote control, press Menu, 1, 6, 7<br />2. Press Mute button on your remote control for All Regions (or 1, 2, etc., for regions 1, 2 and so on).
  4. k thompson
    k thompson
    thanks guys
  5. hipfidelity
    hipfidelity
    Have tried the first hack (from DVD Concept) and it works but the screen is black and white. I think I must have one of the earlier models because the 2nd hack doesn't work at all. Any ideas on why my screen is playing up? Thanks.
  6. Geoffc10
    Geoffc10
    your tv may not be able to display NTSC signals. Although if your tele has RGB scart , you should be ok
  7. hipfidelity
    hipfidelity
    Thanks a lot Geoff.
    I will have a look at the scart - or my TV's days are numbered...
