Matsui 100R DVD Recorder - £99 @ Dixons
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Drogo, Mar 28, 2005.
  1. Drogo
    Drogo
    Dec 13, 2003
    289
    English Riviera
    Sweet player for £99 - just bought one for mum and installed.
    Enjoy, multi-region hack below :-
    Open tray.
    Press DVD/REC
    Press Return
    Press Info
    Enter 8880
    Regards
    Drogo
  2. Gloworm
    Gloworm
    Hi Drogo, I just bought the Matsui £99.99, easy to use etc but the quality on replay is terrible. I wonder what I,m doing wrong.
  3. Drogo
    Drogo
    Dec 13, 2003
    289
    English Riviera
    What recording mode have you got it set to? Let me know what the problem is and i'll try and help.
    Regards
    Drogo
  4. Gloworm
    Gloworm
    Thanks for the offer. I've just found I wasn't set to scart under the setup/video option, this has improved matters. I use the timer quite a lot & select the prog to record from the prog buttons at top rt of remote, is that correct?
