Matrox G400 Marvel good for HTPC
Discussion in 'Desktop & Laptop Computers Forum' started by jbalat, Jan 3, 2003.
  1. jbalat
    jbalat
    I know the Marvel is a little slow for games but picture quality seems pretty good plus it has a tv tuner built in and good support for dvd ?
    I have just purchased the PT-AE200 from PJ and want to run it from the Matrox. I have not connected it to anything yet
    Matrox has their own tweak utility that lets you select the screen resolution.
    Is it ok to use the matrox util or should I be using powerstrip?
    I am asking because most games will only offer 640x480, 800x600 etc. This means the game will just scale to that resolution whereas powerstrip may scale it back ???
    (Australia)
  2. jbalat
    jbalat
    Just in case
    If anyone is running Pal on a AE200 with powerstrip can you please post me your settings ?
