Matrix Switches???
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Romney, Apr 24, 2005.
  1. Romney
    Romney
    Hi - somone has told me about something called a Matrix Switch that you can use for biewing Sky in your house. Does anyone know of these? Are they legal? Do they actaully work?
    Any help appreciated.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    well to watch sky you need a sky box and card, exactly what are you trying to do?
  3. Romney
    Romney
    I already have sky installed - it was an electrician friend of mine that said a matrix switch can be added to your sky box, and then wired up to allow viewing of sky in all rooms of the house, whilst also allowing the watching of different channels.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    you can do this, have a sky box in every room (up to four of a Quad LNB no need for a MArtix switch) but every box needs a card............................
  5. vex
    vex
    Mar 8, 2005
    2,905
    103
    London, Home Counties & North West
    +261
    IF you want to go above 4 sky boxes then you need a IRS Switch which will give Sky, FM, UHF and DAB at all locations throughout the house.
    Watch out for the sky subs mounting up though!
    As HD says it is the only way to watch multiple channels at the same time from Sky.
    Same channel throughout the house is easier, using a Loftbox which will share the UHF output from the SKy receiver.
