Matrix Switcher
Discussion in 'Home Cinema Buying & Building' started by s_tether, Aug 5, 2005.
  1. s_tether
    s_tether
    Jan 18, 2003
    201
    Hull
    +9
    I am after a 4 input, 4 output S-video and audio matrix switcher with IR control to route any of 4 sources to any of 4 zones. I have found a Kramer but it is very expensive and does not have IR control.
    I have found a composite video one but I would really like one capable of S-video.
    Anyone seen one ?
    Thanks in advance.
    Simon
  2. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    I have a Sony PVS 880S matrix switcher. It is 8 input/output for composite of which 4 of the inputs/outputs can also switch S-video. I cannot remember whether there is conversion between composite and s-video. It is a broadcast item so of very high quality. Unfortunately it does not have IR control but does have RS232 control and a number of memories to hold pre configures routes. It is also quite large, about the size of a large power amp.
    PM me for more info if you are interested - or anyone else for that matter but it may be overkill if you are looking for a smaller 4 input/output unit.
    This is a link to the brochure
    -Ian
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,577
    The Borders
    +3,030
    s_tether
    Its always fun seeing folk accusing Kramer Electronics of being expensive - in this market they offer about the best value for money you can get.
    A key consideration for you is how long the cable runs your planning are - anything over 15m and you should factor in a distribution system that includes variable line drive on each output.
    If you require IR control of the Kramer VS-4x4YC it is possible to add a third party IR to RS232 controller to the Kramer unit (more money but does what you require).
    Best regards
    Joe
  4. Chaucer
    Chaucer
    Jul 19, 2004
    38
    11
    Bicester
    +7
  5. s_tether
    s_tether
    Jan 18, 2003
    201
    Hull
    +9
    Many thanks, just what I was looking for.
  6. jason5d
    jason5d
    May 5, 2005
    4
    am interested in the switcher
    are u in the UK and what are u looking for it?
    jason5d
    j@5dg.org
  7. holdmade
    holdmade
  8. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Kramer and expensive are two words that don't normally go together. GREAT value, I'm a big fan.
