Matching Rear speakers with hi fi fronts?
Discussion in 'Home Cinema Speakers' started by Thiswayup, Dec 4, 2004.
  1. Thiswayup
    Thiswayup
    Hello all.
    I 'm trying to find a set of home cinema rear speakers that matches well with my AVI hi fi front speakers which i love to bits( ilisten to a lot more music than DVD"s). I managed to find an ex dem one for the centre but dont want to spend 500 quid on another set of AVI's just for the rears.Also intend on either buying a denon 2805 or a Arcam AV250 multi channel amp and a sub when i have some more cash.I have listened to a few compact sub sat packages but most are pretty weak with music.
    Any suggestions would be much appreciated.
    Cheers.
    TWU
  2. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    I don't think that front to rear matching is as important as having a similarly voiced front three and as long as you buy something that isn't outrageously different you won't have problems with films.
    I used Mission rears with M&K fronts for quite a while and whilst multi channel music wasn't very good it was fine for films.
