Matching Purchased Movie artwork on Apple TV/iTunes Advice please
Discussion in 'Apple Forum' started by Carl32, Apr 28, 2016.
  1. Carl32
    Carl32
    Jun 12, 2006
    433
    +27
    I was wondering is there a way to show the same movie artwork on apple tv once you've added your own in iTunes ?
    For some reason when you add your own artwork its different under purchased movies on apple TV. Is this because the iTunes store have separate artwork ?
    It shows the artwork I've added under computers/home sharing on apple tv but not in the movies purchased section, I was just wondering if theres a way for all the movie artwork to be the same on apple tv in the different sections ?
