Matching power amp to processor
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by Zepfan, Mar 18, 2005.
  1. Zepfan
    Zepfan
    Oct 24, 2003
    61
    How important is it (if at all) to match power amps with processors? I assume it is the processor which gives the sound its "feel" and the power amp gives the grunt.
    I've just bought a s/h Rotel 1068 and want something to match with it & M&K K series speakers. Preferably 6 channels. Any one used the NAD T973 and care to comment on its performance. Would it be a good match with the Rotel?
    Cheers :thumbsup:
  2. Wannabe-THX
    Wannabe-THX
    Apr 7, 2004
    233
    Your better off IMHO trying to get an RMB-1075 and say an RB-03 or RMB-1070.
    Why do you need 6 channels? are you running 6.1 or something.
    Fish
  3. Zepfan
    Zepfan
    Oct 24, 2003
    61
    Yeah - I am running 6.1. So looking at any options really :)
  4. Mr Underhill
    Mr Underhill
    Jun 29, 2002
    88
    +6
    I had a Parasound processor, in fact it's sitting under my bed upstairs, that was v.good - but when I switched to a Naim AV2 it really clicked with my Naim amps. I burrowed the AV2 for a weekend and it didn't go back!
  5. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    My Bryston powers matched very well with my TAG processors, but sound became a bit aggressive when I got a Krell processor...
    My new Bel Canto power matches the Krell very well...
  6. Thunder
    Thunder
    Feb 26, 2004
    1,763
    41
    +14
    Theres not usually any problems matching different make processors and amps :) I use a Parasound with my Tag and it sounds great, of course keeping it all the same make is a bit of a safer bet as they will be designed to work together (output level versus input sensitivity etc) If you are gonna mix makes make sure you have a good listen first :thumbsup:
