Masthead amp required
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Stereo Steve, Jun 22, 2004.
  1. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    Not sure which forum to put this in but anyway, the builders on my house will be bringing a roof ladder later this week which gives me a chance to put up my TV airiel. I have an antiference splitter with 12v DC supply for a masthead amp but Maplin don't have any stock.
    Anyone know of a internet mail order company that I can get an amp from in a hurry (next day delivery)?.
    Would prefer antiference unless anyone has a better suggestion. Also, Maplin sell a 13db and 24db one. Should I get the most powerful? I'm marginal for Freeview although next door gets it fine. I have bought a big Triax hi gain airiel.
    Thanks in advance.
  2. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    Found a Triax one on CPC.
  3. simon123
    simon123
    May 14, 2003
    302
    +8
    i visited the antiference stand at the cai trade fair last week and they have just released a new range of fully screaned masthead amps with f connectors which is very important
    if you are using a triax 32 or 52 you will already have a reasonable signal level,what is important with amplifiers is that you dont dont use one to strong or you will overload with signal
    i sugest you contact a cai aerial rigger because you cant guess the signal you need a signal meter to test the levels and fit the correct amps
  4. JefUK
    JefUK
    Mar 31, 2002
    448
    28
    +54
