Master COMPONENT Controller - Worth the dosh??
Discussion in 'Nintendo Wii-U & 3DS' started by arcam007, Dec 20, 2006.
  1. arcam007
    arcam007
    Nov 30, 2006
    350
    +5
    Having just got a Wii I need to get another Component slot. Some of you have solved the problem by getting a YPbPr Power Box from play Asia. Most seem happy with it but I've been looking at a Master COMPONENT Controller. It seems to be a decent bit of kit and is a 'What Home Cinema Award Winner 2006' for what it's worth.
    http://www.js-technology.com/produc...id=49&osCsid=1daaef465f54aa27072c9b7135744f6b
    I love the fact that it has Automatic Priority switching, it means I can hide it away, and not have to worry about trying switching it over everytime.
    Does anyone have one? Any comments?
    Thanks.:)
  2. JonStatt
    JonStatt
    Nov 18, 2004
    3,352
    103
    +445
    Yes...its an excellent device. It has 80Mhz bandwidth which is higher than most, meaning it won't affect the quality of the signal being passed through it. The automatic switching works perfectly...and you can daisychain them if you later want another input.
    It is really a set-up and hide device. It does require a power supply which it comes with.
    Jonathan
  3. arcam007
    arcam007
    Nov 30, 2006
    350
    +5
    Cheers Jonathan.:)
    The need for a power supply is the only downer, I'm struggling for sockets as it is.
  4. arcam007
    arcam007
    Nov 30, 2006
    350
    +5
    Anyone else got one?
  5. tjradiohead
    tjradiohead
    Jul 29, 2005
    4,036
    71
    +58
    If you can afford it, go for it.
    The power box is tat.
  6. cu3ed
    cu3ed
    Jan 7, 2006
    328
    +6
    Mine just arrived to day, its really light so quite basic, but it has far better connections as far as i can see.
    Unfortunatly im still waiting on my other Component cable to arrive and then will get to test it out.
    Dont see my Premium Wii cable arrving this side of chrimbo
    Oh and i tried the one from Play Asia.........................imsedning it back, complete pish
  7. stu.artd
    stu.artd
    Jul 29, 2005
    3,895
    +333
    If you're happy to pay for it then go for it.
    I have the cheap one from playasia and have found it very good, in stark contrast to the 2 posters above.
    Evidence of the quality can be seen at the links below, 360 in HD running through it. Maybe I'm lucky, I have no idea, but the quality of the cheap little powerbox I got does me fine.
    http://stuartd.smugmug.com/gallery/1400055/1/66228875/Large
    http://stuartd.smugmug.com/gallery/1400055/5/78538556/Large
    http://stuartd.smugmug.com/gallery/1400055/5/78538558/Large
  8. cu3ed
    cu3ed
    Jan 7, 2006
    328
    +6
    To be fair to the Powerbox, it has had 50/50 results, it didnt work for me, but i would guess their could be many reasons for this.
    Although it works fine when just connecting interlaced, but when switched to progressive it just turned to poo lol.
    But, it could be any number of things.
  9. lyndley
    lyndley
    Nov 20, 2006
    23
    3
    +5
    See I'd have one of these but it only gives you one extra input, if you're running an xbox + ps2 plus Wii through component it starts to get a bit expensive especially once you add in all the high quality cables needed to daisy chain.
  10. cu3ed
    cu3ed
    Jan 7, 2006
    328
    +6
    Ps3 would you not just use HDMI though?
  11. dan653
    dan653
    Mar 26, 2006
    1,287
    48
    nr Stonehenge
    +49
    he said ps2, and dont forget your modded xbox too
  12. arcam007
    arcam007
    Nov 30, 2006
    350
    +5
    That looks very sharp.:cool: What is the source?
    I've only my Wii and 360 to contect up at the min, PS2 is in another room at the min.
  13. tjradiohead
    tjradiohead
    Jul 29, 2005
    4,036
    71
    +58
    Photographs are useless when lookin at picture quality imo.
  14. Krill
    Krill
    May 19, 2005
    1,395
    Market Harborough
    +198
    I also have this and it's excellent. I looked at all the expensive options and then someone suggested this. I thought I'd take a gamble for that amount of money and it paid off. It's excellent :)
  15. steggy
    steggy
    Apr 3, 2006
    738
    28
    +46
    I'm thinking about getting the JS Tech one sometime after new year. I got some Belkin component leads from PC World for £7, nomally priced at £25. I have nothing to compare them against but they seem to do the job for my DVD player.
  16. stu.artd
    stu.artd
    Jul 29, 2005
    3,895
    +333
    The source is a Natasha Bedingfield HD music video download from the 360 marketplace ages ago along with FN3 and DOA4.
    Photo's are a reasonable way to gauge picture quality imo, certainly better than simply saying something looks good or bad as people can judge for themselves.
