Hi All
2 questions really, will i get any significant benefit from massloading my MS904 Avants? and how much of the chamber do I fill with sand - half, third, two thirds??
I want to get a bit more bass from my fronts, but I do not want to sacrifice quality. I do not want the sound to be compromised. I was in sevenoaks the other day, and the guys there suggested that mass loading would indeed tighten the bass, BUT that the result may not sound better than before.
Mentioned something about reducing the volume of air in the chamber, thus reducing the amount of bass produced.
Not sure about this guys, what do you think? Will it be bebneficial or not? Any views?
and if I do go ahead, do i half fill the chamber, or what?
Cheers in advance
Cheers guys
Cheers in advance
Cheers guys
