mass loading M73
Discussion in 'Home Cinema Speakers' started by gramee, Jun 28, 2002.
  1. gramee
    gramee
    I was wondering what difference (if any) mass loading the M73's would do....and what material would be best..
    yours in anticipation...
    Graham
  2. smallman28
    smallman28
    It is supposed to improve the bass by making it firmer,if you do fill them the best bet is kiln dried sand from your local builders merchant.
