Mass Effect: Grain and high contrast graphics options
Discussion in 'Xbox Forums' started by SeeNoWeevil, Jan 16, 2008.
  1. SeeNoWeevil
    SeeNoWeevil
    Oct 14, 2003
    2,717
    +874
    Now I see what they're trying to achieve with this but it just doesn't work imo. The grain I don't mind so much but the high contrast robs the visuals of any realism.
    It would have been welcome in a few of the environments but I find it really tiring if used throughout the entire game. It seems developers are using effects like this just because they can.
  2. kav
    kav
    Jul 10, 2007
    25,488
    10
    4
    167
    Scotland
    +13,816
    You can adjust the visuals in the options menu if you don't like the default. :smashin:
  3. RidleyDeckard
    RidleyDeckard
    Dec 5, 2005
    3,637
    Upper Heyford
    +757
    Actually I liked it, I turned it off for a while, but found it made everything look too clinical for my liking to I switch both back on. Each to their own I guess.
  4. Stinja
    Stinja
    Aug 13, 2003
    12,803
    163
    +4,181
    Yep i turned them off after checking each way.
    I laughed in Drake's Fortune, which has a "Next-Gen filter" you can apply, it has all the overblown blooming etc that devs are sticking in games, and does nothing to improve it. Obviously Naughty Dog think some devs are up their own egos too.
    Yes improved graphics can help a game, but really i wish devs would sometimes go "we dont need this X, lets use the processing power to have better AI, or one more simultaneous enemy per fight" and so on. Oh well...
  5. Ico.
    Ico.
    Jul 4, 2006
    3,293
    Mossley.
    +498
    I switched the film grain off. Didn't make it look like a film but made my TV look knak3rd. IMO of course.:rolleyes:
  6. Mark Botwright
    Mark Botwright
    Moderator & Reviewer
    Nov 3, 2006
    8,206
    +1,341
    I actually thought the grain worked quite well. What's this high contrast option? I've only seen the grain and motion blur options.
  7. Ico.
    Ico.
    Jul 4, 2006
    3,293
    Mossley.
    +498
    Think if I remember rightly that there are options for different displays that change contrast settings.
    Some are more "realistic" others were much more vibrant.
    How does all this MABOPIA work...
  8. p9ul
    p9ul
    Jul 29, 2004
    8,837
    +780
    Didnt know you could do this, does it stop the problem of textures going missing? I'm a bit sick of seeing a blank normandy and the game world redering around you as you travel.
  9. Lostsoul 301281
    Lostsoul 301281
    Jan 23, 2007
    6,327
    +1,758
    When I first started playing, I thought the default settings made the game look a crap.
    I was happy to discover that you could turn off both the motion blur and the film grain.
    I mean, I undertand the option of having the film grain, as you have the same thing in Silent Hill 2, 3 and 4, but the motion blur seemed very unnecessary.
  10. shagaboopon
    shagaboopon
    Nov 22, 2006
    3,279
    North Yorkshire
    +367
    20 hours and I've never had that issue, perhaps your DVD drive is on its way out or the disc is dirty.
  11. Beetlejuice
    Beetlejuice
    Jun 23, 2007
    7,564
    Forest of Dean
    +943
    Same here mate. Played for 50 hours and never seen this happen once...
  12. ashwin89
    ashwin89
    Aug 14, 2006
    387
    28
    Surrey
    +27
    Nothing to do with the DVD drive, it's called "texture pop in" and was one of the :thumbsdow that reviews pointed out, I think Halo 3 (or at least definately Halo 2) suffered from it. I think it's the Unreal 3 engine that is the real problem with it, BioWare just had to do the best they could with it.
  13. Brutos
    Brutos
    May 23, 2006
    1,113
    +108
    Yeah Halo 2 was very bad for texture pop-up, infact it didn't so much pop-up as very very gradually appear.:(
    It's not to bad in Mass Effect from what i've seen so far.
  14. SeeNoWeevil
    SeeNoWeevil
    Oct 14, 2003
    2,717
    +874
    You've never seen texture pop in on ME!? It happens on every major load. It's one of the main gripes about the unreal engine.
  15. greektony
    greektony
    Nov 10, 2006
    916
    28
    Fareham/Camberley
    +27
    I think he was referring to texture pop up inside the Normandy as thats what Paul T was babbling on about, rather than during the outdoor levels.
  16. DongaTon
    DongaTon
    Dec 7, 2006
    2,423
    Greenock, Scotland
    +346
    Can anyone tell me where this is? I can only see the film grain and motion blur options.
    Would you recommend I turn both those off? Cheers.
  17. xox Godders xox
    xox Godders xox
    Jan 2, 2008
    1,421
    +316
    I much preferred the look of the game with them on (more "filmy").
