Swiss-Steve
This is from my original post on AVS, I took out all the posts in between, but if you want to see the entire thread it is http://www.avsforum.com/avs-vb/showthread.php?t=754506
Hi Everyone,
Just thought that I would post up what I have been doing to the Rear heatsink on my Marquee 9500LC.
I milled off the original horizontal fins,
Bolted on some 150mm tall heatsinks that have vertical fins.
Used heatsink conductive paste between the heatsinks.
I will be testing tonight to see what the temp difference is.
The Original ran at 65.5'c with the rear cover installed,
60.8'c with the rear cover removed.
Let me know what you think
Steve
Well all looks good so far,
around 5'c cooler at the convergence transistor clips.
This is just the first round of testing, so more data to come.
I expect that the overall temp of the heatsink to be cooler, that test later.
but I have the vertical transistor clip test which is next.
High Dollar Audio Amps, Hmmmmm, well it is a High Dollar CRT if you count the parts that I have put into it with my modifications.
Does look VERY COOL (pun intended) though
Steve
Just another note, I am running with NO bottom cover at the moment,
I do think that the rear heatsink will run cooler as the bottom cover directs air from the FCM and HDM, plus the tube enclosures out of the bottom cover.
So this air should also help reduce temps a little more.
More to come
Steve
OK, This is where I am at now,
Nice, a 9.5'c drop at this point in the curve.
More to come
Steve
OK, This is how the 2 tests finished up last night,
Looks good so far,
Tonight the bottom cover will go on, plus the last test point on the heatsink for the last addition to the graph.
Steve
Here is the most interesting Graph,
Shows the surface temp of the original and modified rear heatsinks.
ALL Previous temps were measured at the transistor clips, right at the transistors.
Steve
Well, I have installed the bottom cover, and will complete the last set of testing of the heatsink this weekend.
I expect that the temps will drop a little as the bottom cover should direct air over the heatsink.
I might install some very quiet fans to the heatsink to see what happens to the temps, will see, if I can get some time after all the other testing,
plus watching a Movie or 4
Have a Great Weekend
Steve
OK, Here is what 4x 80mm fans slapped on can do for the temps, in a short word WOW
So tomorrow I will add another 2x 80mm fans, which will cover the entire length of the heatsink.
These fans are CoolerMaster with the thermister, so they speed up as the temp increases, I can't hear them over the rest of the fans, so NO added noise, and I think that I have the quietest Marquee around.
I have measured it at 29dB.
I have SilenX fans installed in the belly, plus 2x 120mm fans installed in the LVPS
Are you ready for a 30.5'c drop in heatsink temp?????
I can post a snap shot of the data sheet if anyone is interested??
Steve
This photo has not been added to the AVS thread,
But this is the final configuration of the rear heatsink, 4x 120mm fans.
So now, I am the only Marquee to have 10 fans installed
Ask away if anyone has questions
Steve
Hi Everyone,
Steve
Steve
More to come
Steve
More to come
Steve
Looks good so far,
Steve
Steve
Steve
Steve
Steve
