Marking a continuous MP3 track
Discussion in 'Computer Software & Operating Systems' started by iendicott, Aug 28, 2006.
  1. iendicott
    iendicott
    May 3, 2005
    268
    Peterborough
    +5
    I have a continuous MP3 track that I have created from a mix. Now when I burn it the track is just registered as 1 continuous track, is there a way in Nero to mark each new track without psyically splitting the track like they do on some live mix CD's ?
  2. tinners
    tinners
    May 22, 2006
    3,288
    Bucks
    +242
    Can you not split the MP3 at the start / end of each track then burn them all with a 0 second delay between tracks in Nero ?
  3. Werner
    Werner
    yes, once you have dragged the wav file over to the left hand window, right click it and select properties. this should open the nero wav editor and allow you to add track markers at specific spots etc.
