Mark grant cables v qed and audioquest ?
Discussion in 'Cables & Switches' started by Singhisking, Mar 9, 2013.
  1. Singhisking
    Singhisking
    Apr 30, 2011
    4,207
    London
    +207
    Hello guys I'm buying new following cables of HDMI, digital coax for denon link, optical and a subwoofer cable. What I want help with is are qed and audioquest overpriced etc and are mark grant cable better to buy also what would be the best cable for each item I am looking for all comments welcome
    Thanks for your help people :)
  2. larkone
    larkone
    Apr 21, 2006
    4,264
    134
    North Essex
    +1,179
    The digital cables (optical or copper) will not be any different picture or sound wise between the different makes other than a possible manufacturing quality difference. They will all carry and deliver exactly the same signal whether your spend hundreds or buy them off Amazon for a few pounds. That is a £1000 Audioquest HDMI cable will not outperform a £2 budget version of the same. Mark Grant's products are well made and he provides a good service.
  3. Craig uk
    Craig uk
    Nov 20, 2007
    3,413
    Norwich
    +962
    You just forgot to put the word 'fact' on the end. :lesson:
    Why not contact Mark Grant and ask his opinion? I'm sure he would offer a home demo on any cables you are interested in. Only then will you know if they make a difference and justify the asking price.
  4. Singhisking
    Singhisking
    Apr 30, 2011
    4,207
    London
    +207
    Ah okay guys thanks for your help will look into it more :)
