Quantcast
Mark’s garage conversion thread
markie g
If the thinking is to joint the cables, then cover over with something, so it can’t be seen, i.e. plaster, then don’t think that way anymore :)
Is this allowed? I have to have a certificate for all electrical work complete to show the council.
markie g
Garage door off and some of the toothing done
Builders will finish it tomorrow and start bricking up
Didn’t think about how dusty it was going to be!
markie g
Just having a look and a bit unsure why they’ve gone that far on the left, i assumed it would be the same as on the right
markie g
Ok spoke with the builders today regarding the left section, apparently the left section only had one row of bricks, rather than 2 rows, which meant when they tried to tooth them out the bricks crumbled as there was no support behind. So without taking it all the way round the the side of the house and support and re-bulding the corner there's not much they can do but just make it look the best they can.
Not ideal, but just goes to show a simple thing can't always be straight forward :(
Munzz
Good luck Mark. We moved in to our home last year, the 2nd "garage" was partitioned off so we ripped it down and merged both rooms (see photo). So far, we've blocked up the garage door, put in a window, x2 Velux roof windows and that's all.
It will be my project to complete next year more than likely, but the space is brilliant.
markie g
Lovely tidy brickwork. Why have you cropped out the LHS?
Only reason is that on the left is a pile of stuff that needs to go to the tip (old garage door frame), I’ll get a head on view tomorrow after I’ve nipped it to the tip and it looks a bit tidier :thumbsup:
markie g
Sourced all the bits flooring now, updated the first post.
Width of the garage is about 2.38m, and the boards are 2.4m so might even get away if them sliding straight in, if not just a tiny bit off.
Going to level the lower part of the garage my self and give it a good couple of days to set, then will crack on with the flooring
Also, @Wahreo totally forgot to get you that picture, this is the best i have, taken on a wet rainy day. Gives a good idea of how it looks in relation to the rest of the property (the mortar was still drying at this stage).
MSW
I think it looks absolutely fantastic, really well done, you must be extremely please with with how it’s all looking
markie g
Flooring stuff arrived today, having to work from home until further notice, so might be able to starts bits of this in the lunch break and hopefully get it finished at the weekend
markie g
Flooring down, luckily insulation and chipboard only ever so slightly needed trimming
Dony
How wide is the room? It appears very narrow to have been a garage but that might just be the camera playing tricks.
Wahreo
Average garage in a modern new build. Not designed to actually fit a car in, built purely to tick the box stating that the house has a garage.
jonna
We converted our garage 25yrs ago. It’s been a playroom, an office, a cinema room and now it’s a utility room.
Similar threads
Trending threads
Latest News
MQA expands global partnerships for high end experience
  • By Andy Bassett
  • Published
Samsung 2020 TV app lineup upgraded
  • By Andy Bassett
  • Published
Film festivals move online: We Are One starts 29th May
  • By Andy Bassett
  • Published
Bafta 2020 TV Awards to proceed behind closed doors
  • By Andy Bassett
  • Published
Tidal brings Dolby Atmos Music to home cinema setups
  • By Andy Bassett
  • Published
