Marble or a tile
Discussion in 'Home Cinema Speakers' started by rjcowan, Dec 19, 2002.
  1. rjcowan
    rjcowan
    May 3, 2001
    210
    Comber
    +5
    I have a wooden floor and with the sub sitting on the wooden floor it eats up the bass. I hav been told before about putting a marble slab under it. These are not easy to come by but would a tile be just as good. also do you but rubber feet on the marble/tile or just lay it straight onto the floor?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,905
    To be effective you will need to place something as heavy and solid as possible under the sub. A tile probably wouldn't be of use.
  3. jflynn
    jflynn
    Wickes(and others no doubt) do granite tiles about 18" square for approx £6(very heavy).They are about half an inch thick so two or three of those bonded together would give a marble slab a run for its money.
  4. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    yes to the rubber feet (sheet rubber maybe better) and the denser and thicker the material the better.
    from recent investigation into purchasing a granite slab I discovered they were bloody expensive but have managed to find a slate slab cheap about an inch and a half thick, which isn't really thick enough but like I said it was cheap.
    it sounds like you may benefit from putting a duplicate slab on top of your sub as well to hold it in place.
    Paving slabs from all the usual DIY stores are perfect but some people can't stand the look of them.
  5. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +226
    I use paving slabs to good effect, just painting them the same colour as the carpet...with car paint and lacquer.
    I've found spikes, on the base of the slab bring futher benefits...too.
    spence
  6. alexs2
    alexs2
    Nov 13, 2002
    13,897
    +1,671
    All of these are OK...but nothing beats spikes,if the sub has fitting for them.....and bed the spikes into the floor really well...also repeat that a while after fitting and using using....everything tends to loosen after a while.
  7. James45
    James45
    Sep 21, 2002
    2,844
    59
    spikes dug into the wooden floor would surely transmit vibrations wouldn't they? Plus I doubt many people would want to make spike holes in their wooden floor.
    I use hefty spikes for my AV rack on a carpeted floor and may use some on my sub slab but if I had a wooden floor I would go with rubber feet
  8. rjcowan
    rjcowan
    May 3, 2001
    210
    Comber
    +5
    So we are all agreed that I require a slab or paving stone 2-3 inches thick and a layer of rubber or rubber feet to go on the bottom of the slab/paving stone.
    This is going to be fun to find.
    Ann Summers for the rubber and a funeral home for the marble - great.
    I think i may go for a paving slab and paint it black, as for the rubber feet I am looking into it.
    Thanks for the advice
  9. dts_boy
    dts_boy
    Nov 26, 2001
    2,589
    Manchester suburbs...
    +178
    i was recently told that if you screw some phillips head screws into the floor and then sit your spikes in the screws, this tightens up bass dramatically. has anyone tried this, i wouldn't dare as i value my realtionship with my wife:blush:
  10. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +226
    I use to use a penny under each spike to prevent damage to the woodblock....without sacrificing sound quality to any extent, that i could hear.
    Throw the boat out and use 50p under eack spike if you're after the ultimate though. :)
    spence
  11. Charlie Whitehouse
    Charlie Whitehouse
    I've got these under my Martin Logans. Be aware that they are smooth on one side and very rough on the other. I would suggest using the rough side down with a layer of thin (thinner the better) felt stuck to it to avoid massacring the wooden floor surface. Any kind of rubber feet will only allow the speaker to rock which defeats the whole object. ;)
  12. jasonb
    jasonb
    As a thought would I get any benefits in sound quality by covering 2 paving slabs in felt and putting one underneath the sub and one on top. Also does anyone knoe if any of the DIY stores will cut the slab to the exact size so to make it a bit more pleasing to the eye. I'm currently using a sevo 15 which is quite large already and rectange in shape.
  13. James45
    James45
    Sep 21, 2002
    2,844
    59
    I know at least one forum member has already covered top and bottom paving slabs in felt and reported that it work fine. the stone cutting appears to be the most expensive thing about stone.
    I wanted a circular granite disc, about two-three inches thick for my circular Gallo sub to sit on and give it something solid to fire off of, squares of granite would have been much, much cheaper.
  14. installer09
    installer09
    Aug 26, 2002
    415
    16
    SWINDON ,WILTS
    I got granite slabs cut at a stone masons , one piece 30m thick for under my sub and two pieces 20mm thick for under my dvd player and amp , cost £70 . Apparently Granite is better than marble as it has a more uniform consistancy.
