Marantz VP7200 SILVER (Projector)
Discussion in 'Projectors, Screens & Video Processors' started by Bill, Mar 1, 2003.
  1. Bill
    Bill
    Oct 31, 2002
    509
    3
    Dungannon
    +32
    Richer Sounds are offering this for £1299.95, does anyone have any previous experience of this model.
    http://www.richersounds.co.uk/index.php?f=itemdetl.php&p=300254
    I also noticed they say it doesnt come witha remote control, but the Marantz site says it does. I have e-mailed them and awaiting a response on this currently.
    Would the fact that it only seems to take an S-video input be a big problem with a projector, yes I've never owned one yet?
    Cheeers,
    Bill.
  2. Kramer
    Kramer
    It wouldn't be my choice for HC :nono:
    800x600 (SVGA) resolution - only 4:3 panel.
    350:1 CR
    2000 hrs lamp life.
    Added to this, it's £500 more expensive than an AE100 :eek:
    Not seen any reviews, but I'd definitely look at something else.
    :hiya:
  3. Bill
    Bill
    Oct 31, 2002
    509
    3
    Dungannon
    +32
    I was thinking of the panasonic, it would be ideal for my budget . I see that you can get it for around $800 but when I asked Sound and Vision they said they dont deliver to Northern Ireland, only the mainland. So unless I can find another source.....
    I really have a budget of around a grand or thereabouts, and there is a Richer Sounds in Belfast, so I was just checking out what they had. I hadn't heard anything on the Marantz before.
    I see you have upgraded from the panasonic, have you sold your old one yet?
    Cheers,
    Bill.
