Marantz vp-7200, is it any nice?
Discussion in 'Projectors, Screens & Video Processors' started by ltrulsse, Oct 10, 2003.
  1. ltrulsse
    ltrulsse
  2. cyberheater
    cyberheater
    Apr 3, 2003
    3,225
    Scotland
    +179
    Looking at the feature set (especially contrast ratio) I would say don't touch this with a barge pole.
    For a 1000 pounds or less, you should be able to get either:-
    1/ Sanyo Z1
    2/ Infocus X1 (or equiv)
    3/ Panasonic AE200
    All will give you a much better image.
    FEATURES
    * Active Matrix LCD Panel
    * SVGA (800 x 600) Resolution at 1250 ANSI Lumens
    * Contrast Ratio 350:1
    * Compatible with PAL, NTSC, SECAM and HDTV-Ready (480p, 720p, 1080i) video and PC (VGA to SXGA) signals
    * Auto-image for automatic Data/Video selection
    * Digital Keystone Correction
    * Digital Zoom, Freeze
    * Color Tracking
    * 150W Lamp with 2000 Hours Lifetime
    * Auto Standby
    * Auto Image Quality Correction
    * External Monitor Connection
    * High Quality Optical and Electrical Components
    * Easy setup, Ultra Low Fan Noise Compact Remote Control with Cursor Control
