Marantz VP-12S1
Discussion in 'Projectors, Screens & Video Processors' started by pcavelle, Jun 4, 2002.
  1. pcavelle
    pcavelle
    Jan 23, 2001
    986
    London
    +16
    Has this projector surfaced in the UK and has anyone had a look at it?
    Does the bulb flicker still? This was/is a problem that Marantz have acknowledged.
    Paul
  2. MikeC
    MikeC
    Mar 14, 2001
    225
    Northants,UK
    +10
    Paul
    I currently have this pj which I have had since Saturday.
    I will post detailed comments later.
    So far I am pretty pleased with it :)
    So far the flicker problem has been a non-issue (I am using s-video)
    but did (I think) notice a slight flicker when using a pc connected to it.
    Mike
  3. reefer
    reefer
    Do you notice any Jeffry, Bungle & Zippy from the DLP? :clown:
  4. pcavelle
    pcavelle
    Jan 23, 2001
    986
    London
    +16
    Hi Mike
    Did you get it for a reasonable price?
    Paul
  5. MikeC
    MikeC
    Mar 14, 2001
    225
    Northants,UK
    +10
    reefer - not quite sure what you mean ? :confused: - is this technical :clown:
    Paul - it was uk sourced (not grey) so wasn't cheap
    I bought it via the Sound & Vision show back in Feb so got a good discount (minimum 10% off).
    I did debate whether to buy from Japan (see AVSFORUM for further info)
    but what with the risk of problems with this relatively new technology, took the desicion to buy a uk one.
    Mike
  6. reefer
    reefer
    ie do you see any rainbow from the dlp colourwheel? :clown:
  7. MikeC
    MikeC
    Mar 14, 2001
    225
    Northants,UK
    +10
    O i c (me being a bit slow here)
    The answer is no during normal viewing (so far that is).
    The only time I have noticed a rainbow-like effect was when projecting the focus matrix
    screen (part of the pj - white h/v lines on black background).
