Marantz Upgrade
Discussion in 'AV Receivers & Amplifiers' started by saibot, Jan 10, 2005.
Tags:
  1. saibot
    saibot
    Jun 28, 2004
    1,231
    Near the Lee - Ireland
    +42
    I'm thinking of upgrading my Marantz 6200. After reading lots of nice reports on the SR-7400 here, do people reckon this is a worth while upgrade ???
    Not really gaining much but an extra channel (7.1) component in & out ( handy for my PJ) and a few extra sound decoders, so wondering if all this is worth the 400ish I would pay to upgrade.
    Or would I be better, buying some external power-amps to give the 6200 a bit more power???
    ta,
    d... :)
  2. tom_nieto
    tom_nieto
    May 21, 2003
    418
    Brighton
    If you're happy with your decoding options and can live without the component connections, then I would add some power amps to the mix.
  3. jasonuk
    jasonuk
    Dec 26, 2004
    149
    16
    its available for a bargain £350 from hi way group.
    check it out.
    better be quick before stock runs out.
