Marantz Tape Deck Advice Needed
G
g12345567
I have two marantz tape / casette drives here that both need the drive belts replaced.
1) Marantz SD-53 (single deck - around 1995) Single belt.
2) Marantz SD-64 (digital monitioring - single deck) Two Belts.
The problem is I'm unsure of exactly what size belts I need to buy for each tape drive. The SD-53 looks easy to install but the SD-64 I'll probably need instructions or help on installing that one as I haven't figured out exactly where the bels go as its alot more complicated.
If anybody can help with belt sized needed, as well as installation instructions / service manuals pdf etc that would also be great.
Rocky 4K, Creed 3 and boxing movies, Shazam 2, 65 trumping Jurassic World Dominion, + Picard & Mando
