Marantz SR8002 - Display problem
Discussion in 'AV Receivers & Amplifiers' started by carlosalberto, Aug 26, 2013.
Tags:
  1. carlosalberto
    carlosalberto
    Oct 19, 2010
    Hi !
    My name is Carlos , live in Sweden and I am a happy owner of a Marantz SR8002, but I have a problem, I have been configuring my remote control Philips Pronto TS9600 soon, and testing with my Marantz SR8002, remote control turn off the display of my Marantz .
    I did a master reset of the Marantz SR8002 and the display doesn't light up, took the amplifier to a service center and tell me that everything is correct, there is no defective component,.
    You could suggest me a possible solution
    Tank you
    Regards
    Carlos Barrera
  2. Philip4242
    Philip4242
    Jan 15, 2008
    1,021
    UK
    +167
    I don't know what language User Manual you have, but the English one clearly states :-
    'You can select the display mode for the front display
    of the unit.
    To select this mode, press the DISPLAY on the
    remote controller or the front panel.
    When this button is pressed, the display mode is
    switched in the following sequence.
    Input Mode → Surround Mode → Auto display OFF
    → Display OFF → Normal Mode → Input Mode'
    Does that not work ?
    It does seem strange that a 'Master Reset' doesn't give a sensible default !
  3. carlosalberto
    carlosalberto
    Oct 19, 2010
    Hi !
    Thank you all for helping me, my Marantz SR 8002 is home of a technician, is checking that the amplifier doesn't have any broken piece. (resistor ,capacitor ,etc. etc. ...)
    In a few days he will be back in my house .
    Refards
    Carlos Barrera
    Pd. I did a master reset, but the display not illuminated
  4. carlosalberto
    carlosalberto
    Oct 19, 2010
    A technician check the receiver Marantz SR8002, and it found nothing blown inside (removed all the receiver) , I did several master reset (, but the display is still dead , I have used the remote control that caused the problem, and nothing (Philips Pronto TSU9600) ,Press the buttons: "display", "pure direct"... and nothing .
    Thank you very much for helping me
    Carlos
