Marantz SR7400 - Is bi-amping possible?
Discussion in 'AV Receivers & Amplifiers' started by Falp, Oct 4, 2004.
Tags:
  1. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Is it possible using the 6 & 7 channel to bi-amp the front channels with a Marantz SR7400 like in some Pioneer receivers and Denon 3805?
    Thanx! :)
  2. Antpink
    Antpink
    Jan 18, 2004
    468
    43
    Singapore
    +100
    I found this site while surfing - you can find the manuals for just about every Marantz product in it, including the SR7400. I have downloaded, but not read it yet, in anticipation of my purchase of one of these amps tomorrow.... :D
    www.marantz.com/pdfs/
  3. ash71
    ash71
    May 24, 2004
    70
    I don't think it is.
    You can either use the SBL and SBR speaker outputs to drive the centre back channel/s for DD EX and dts ES, or if you run with a 5.1 setup instead you can assign them to stereo multi room duties. There is no facility in the set up speaker options (or any other menus) to bi amp the front left and right channel.
    BUT you can drive 2 sets of front speakers (A, B, A+B) not strictly bi amping (I think?) but don't know what would happen if you plug both speaker outputs, spk output A and B Left and A and B Right, into the their 1 pair of speakers. NOT going to try this with mine anyway!!
  4. Kazman
    Kazman
    Jan 14, 2004
    5,349
    Luton, Bedfordshire
    +142
    You are a star, I've been looking for their manuals for bloody ages :D
  5. Kaleb500
    Kaleb500
    Apr 4, 2004
    57
    can't you set it up so A left and B left drive the left speaker and A right and B right drive the right speaker. Then enable A and B?
