Marantz SR7200 to Denon 3805 - worthwhile upgrade?
Discussion in 'AV Receivers & Amplifiers' started by Radiohead, Jul 15, 2004.
Tags:
  1. Radiohead
    Radiohead
    Dec 24, 2001
    4,405
    Amazingstoke
    +440
    I'm becoming more and more tempted by the new AVR-3805 - is it worth going from my existing Marantz SR7200 to the 3805, or am I simply suffering from a case of the itchy feet?
    Alternatively, would the 2805 be a worthwhile move?
    I don't intend to use 6.1 or 7.1......and listen to movies/music in a rough 70/30 split.
  2. bobbypunk
    bobbypunk
    your music quality will drop by a fair bit, your movie sound will improve significantly but if quality of sound is your main thing then wait for Marantz's new models!
    Well thats my opinion anyway!
  3. Radiohead
    Radiohead
    Dec 24, 2001
    4,405
    Amazingstoke
    +440
    Thanks for that
    I'm trying to arrange for a home demo of the 2805/3805
  4. kumamoto
    kumamoto
    Sep 2, 2003
    1,151
    38
    Watford
    +17
    If stereo music matters to you then it best to stick with Marantz, however Denon 3805
    is pretty good in stereo as well. I had a Denon 3801 and i ditched it for a Marantz 9200 and have never looked back.
    Still if you have a dvd player that can take advantage of Denon Link (Denon A11) then 3805 will be a general improvment sound wise, not to mention the automatic setup,Upconverting and loads of other features. The denon in Dolby Digital and DTS is simply brilliant.
    It a tough choice.
