Question Marantz SR7200 goes into standby mode on power up
Discussion in 'AV Receivers & Amplifiers' started by Murdoch123, Dec 19, 2016.
  1. Murdoch123
    Murdoch123
    Dec 19, 2016
    San Francisco
    15 year old receiver, just stopped working. I have it plugged now directly into the wall, no speakers or components connected - the unit powers on and immediately goes into standby mode. Has anyone experience this? No remote being used, nothing.
  2. Nobbynorbs
    Nobbynorbs
    Sep 16, 2018
    knutsford
    Hey Murdoch123, did you ever get to the bottom of this? Mine does exactly the same. If you press one of the source buttons, the unit pwoers up momentarily and then switches back to standby again. It does the same if you press the multi-room button from standby too. I'm doing this with no input or speakers - it makes no difference whatsoever.
