Marantz SR7200 6.1?
Discussion in 'AV Receivers & Amplifiers' started by guyb, Apr 27, 2003.
Tags:
  1. guyb
    guyb
    May 20, 2001
    642
    Leamington Spa
    +5
    Hi All
    I have just bought a Marantz SR7200 Receiver
    On the receiver there are no Dolby Digital EX and dts-es logos but in the manual it states that it supports 6.1 - “…. This mode is suited to 6.1 encoded material such as Dolby Digital EX and dts-es”
    So does this mean the receiver can decode Dolby Digital EX and dts-es (matrix, discrete)?
    Guy
  2. puddleduck
    puddleduck
    Jan 24, 2003
    1,816
    48
    Lake District, near as dammit
    +50
    I don't have your amp. but I suspect you will be able to correctly hear both DD EX and DTS-ES with the extra rear channel.
    I doubt the 7200 will decode ES Discrete, but as Discrete has the rear channel maxtrix'd in anyway, you will still be able to hear it OK, even without a Discrete ES decoder.
