Yes it can! Don’t know where it is in the menu
can the small circular window display on the Marantz models be turned off [including the blue ring light surround] when in use?
Thanks. There is no dimmer button [quicker method] on the remote? Can the small circular display on the front show soundtrack info etc... i.e DTS/DD/DTS-HD/TrueHD?To turn off the blue ring light hold down the Dimmer button on the front panel for 3 seconds. To turn the display off go into the setup menu to General - Front Display.
Thanks for the informationNo. You'd have to use the display behind the drop down if wanting to ascertain what the audio format is.
not using power amps but i would never connect cables to amps while on.Just set the 7011 up roughly, as I won't have ceiling speakers for a few days and my grandson is helping! Has anyone set the trigger up for power amps? instruction is not clear to me. It says to connect the lead with power amps on but further on it tells you to turn the power amp/s on? any help appreciated- Don't want to take a chance with power amp and new receiver.
Would like to say thanks to Steve at Peter Tyson for expediting delivery of my receiver after I made an ordering error
I have heard that the 6011 can run really hot and is a concern for me. My current amp just fits into my rack but is open on both side so plently of space for the vents on the side so has never overheated. I believe both marantz amps are slightly shorter then mine so this might not be a problem.
As posted above. Connect the 12v Trigger cables whilst everything is powered off. Turn the Marantz back on and go into the main setup menu to General - Trigger Out 1/Trigger Out 2 and check that those settings are On. Turn the poweramps on and then switch the Marantz off. It should then turn the poweramps off as well. Then just turn the Marantz back on and carry on as normal.
Can't play with receiver as grandson is watching my tv so i'm upstairs on mac how do I select 7.1 inputs from remote and/or receiver (this for my sacd player) cheers. I'm reading the online manual but I'm not 100% at present and there's a lot of manual.
Thanks for that I'll have a play now gs. Gone to bed. I have my sacd player wired fl and fr for cd and six leads for sacd (Sony XA3000ES) it has 8 outputs.
Never used ARC before so I'm not sure about a couple of things. I have my b/ray player and other equipment into the 7011 by HDMI and one lead from receiver (ARC monitor) to the ARC input on my LG E6 (HDMI 2) all work fine but I don't get the tv picture as I thought was the case with ARC. I have to switch to 'live tv' to get this picture and then I don't get the receivers graphics osd overlaid. I've set the 7011 remote up for the tv and assigned sound so no problem there. Is my understanding of what ARC does wrong?
Separately the 7011 gets pretty hot even playing cds in stereo or pure direct even though I'm using separate power amps for the front channels. Do the receivers internal amps remain on even when using outboard amps?
Is there any internal fan on the 7011? There’s no sign of one on the external casework with that I can see, though I haven’t looked underneath.
