Quantcast
Marantz SR5400
D
david park
Anyone useing this AV reciever with a Freeview digibox, are codes known to put into its preproggrammed RC to opperate terrestrial digiboxes.
Also Sky box as well.
Its remote is RC5400SR, I think it will be the same as used with the SR4400 as well.
Do Marantz have customer support in UK, e-mail or Fax number appreciated.
VurtHed
No Freeview digibox codes in manual from the looks of it. The listed manufacturers are under the following headings: CD, MD players, CDR, TAPE, SAT (DSS), TV, VCR, DVD.
There are a 22 manufacturers listed under SAT (DSS).
The remote can scan its code table to find "appliances". I'm not sure that means anything other than another way of finding the appliances listed in the manual.
I have a PACE Twin connected to mine, but have found the Twin RC's buttons too complex to map onto a basic learning or multi remote.
HTH
