Marantz SR5400 & THX?
Discussion in 'AV Receivers & Amplifiers' started by MikeBz, Jan 30, 2004.
Tags:
  1. MikeBz
    MikeBz
    Jan 30, 2004
    13
    Essex
    A query from a newbie...
    Home Cinema's review of the Marantz SR5400 states that it has THX Select. This is in disagreement with the specs on Marantz's website. Does anyone know the truth? Are there different versions of the SR5400 out there, some with THX Select and some without?
    Thanks,
    Mike
  2. calscot
    calscot
    Oct 29, 2002
    664
    16
    Milton Keynes
    It's a mistake, the Onkyo in the test is THX select, the reviewers have got them mixed up.
  3. MikeBz
    MikeBz
    Jan 30, 2004
    13
    Essex
    Thanks!
    Mike
  4. MagicBoy
    MagicBoy
    Sep 19, 2003
    308
    +21
    What else did they get mixed up? :eek:
  5. MikeBz
    MikeBz
    Jan 30, 2004
    13
    Essex
    It does make you wonder... If you're buying on the strength of a review and the reviewer can't even remember which offering had which features... Urk!
  6. Dillz
    Dillz
    Feb 25, 2004
    236
    Gloucestershire
    +8
    I'm confused too. The product spec for the SR5400 at http://www.marantz.com/hifi/europe/ states that it does have a THX certification & THX is listed as one of it multichannel/surround modes.
  7. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    It doesn't have THX Certification :rolleyes:. HAVE A LOOK ON THE FASCIA for crying out loud.
    Do you see a THX badge?
  8. Dillz
    Dillz
    Feb 25, 2004
    236
    Gloucestershire
    +8
    Well that's why I'm confused !!! (for crying out loud), no badge and yet the manufacturers own web site says it is THX certified. As you implied, for this price Marantz would put a wapping great badge on the front as it would be a major selling point. So is this a mistake on Marantz own website I wonder.
  9. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    It's a question that's been asked several times on the forum before.
  10. Dillz
    Dillz
    Feb 25, 2004
    236
    Gloucestershire
    +8
    Thanks Dimmy. I have been ploughing through the many very helpful threads on the SR5400 and couldn't have picked up on it. Basically I am about to purchase my first amp and am torn between the Yamaha DSPAX640SE and the Marantz SR5400. I am pretty set on the MS Premiere + speaker package although it will put me a bit over budget. Fresh from Marantz website after reading about the THX certification I picked up on this thread hence here is confused lil' ole' me. I guess it just comes down to personal opinion at the end of the day, though I still can't decide.
  11. MikeBz
    MikeBz
    Jan 30, 2004
    13
    Essex
    Dillz - I think your confusion is caused by the layout of the spec list on the Marantz website. There a 2 columns, the left hand one has a list of features, TLAs, buzzwords etc., and the right hand column indicates the level of support for that feature. Against 'THX' the right hand column is blank, which is ambiguous - it should contain a '-'.
    Pendantically yours,
    Mike
  12. Dillz
    Dillz
    Feb 25, 2004
    236
    Gloucestershire
    +8
    MikeBz : You are sooo right. Thanks for clearing that one up for me. Must admit I feel a bit of a muppet now. Perhaps time to get the contact lenses updated. :blush:
  13. jeff-o
    jeff-o
    Bah, THX certification doesn't really mean much unless your DVD player, speakers and room setup are also THX-certified.
    IMO THX certification is a little plaque they paste on the front of an amp to drive up the price.
